Create a Link in the Related Tables
2209
03-21-2017 08:46 AM
BrianO_keefe
Honored Contributor
In order for things to work the way that is specified... I have to have a related table with the NAME of the document.
So, for instance, on Feature X, it will have X number of document names in a related table.
What I would like to do... in WAB... is turn those Related Table Document Names into a URL.
So if the document name is SomeDocument.pdf then what I want to have happen is it turns into a clickable URL that is located at: http://somedomain.com/some/path/SomeDocument.pdf
However, no matter what kind of Configure Popup scenario I do? The related table just displays the document name... No link.
Any ideas?
RobertScheitlin__GISP
Brain,
   To my knowledge this is not possible as of yet.
Brain,
BrianO_keefe
Honored Contributor
Your story makes me sad Mr. Scheitlin.
MonicaBeaton
I too am trying to get a return on external documents using related tables. Were you every successful in solving this? My next thought is to try and register the document location in the data store and add it as 'external sources'. Any thoughts or insights? I am building this in an Enterprise Web App in our org's internal Portal. Just curious.....thanks!
