Coordinate widget - label the options
932
02-25-2019 11:48 AM
by Anonymous User
Not applicable
If you add a few different coordinate system options to WAB Coordinate widget, it does not label them. For example 2239 in the following: Decimal Degrees, Degrees Mins Seconds, MGRS and USNG. Edit:::: this is apparently included, as of WAB 2.11 (?) so can be marked as Implemented.
RobertScheitlin__GISP
Kevin,
   You already have the ability to edit the label for each coordinate system used right in the the widgets settings dialog. Just double click in the table on the label.
by Anonymous User
Not applicable
Sweet. I see it.  I was using WAB DE 2.9. It's been on my to-do to upgrade the property mapper I released to 2.11 or 2.12.  I just tried using the latest one (hosted online) and sure enough it is there indeed. Awesome! Thanks for the heads up Robert.
Kevin,
  Ahh, that ability came out in 2.10.
