Configure Coordinate widget - WKID error
2598
08-05-2021 01:14 AM
EvaMueller
Hi all,
on my web app I am trying to display coordinates in the GDA2020_NSW_Lambert projection, using the "Configure Coordinate" widget.
I click "Add output coordinate system" and then want to enter the WKID (8058 as per this list) for this projection. However I get an error "Please input valid spatial reference WKID!"
On the other hand it does let me enter WKID 3308 for GDA_1994_NSW_Lambert with no error.
I have no idea how to fix this issue and I really need to show coordinates in GDA2020.
Appreciate any advice
Thank you
KenBuja
MVP Esteemed Contributor
For some reason, it's not loading all of the WKIDs from that page. For example, it's not loading any of them between 6933 and 20002.
RobertScheitlin__GISP
@EvaMueller  What version of WAB are you using?
KenBuja
This error occurs on the AGOL version also.
I think this is related to the json syntax error in the wkidDetails.json that has been un resolved for several releases now. I guess no one has called tech support about it.
