I went into the \WebAppBuilder\WAB2_0\server\apps\11\widgets\Scalebar\setting\css and changed padding to 10px and the font-size and color:
.jimu-widget-scalebar-setting{
margin:0;
padding:10px;
font-size: 16px;
color: #161616;
The changes are not shown when I launch my app. I cleared my browser cache/history, refreshed, and still no change.
Is there something else I need to change?
Tim,
Hmm... This worked fine for me:
.jimu-widget-scalebar .ruler-style {
position: relative;
top: -15px !important;
left: 0 !important;
.jimu-widget-scalebar .scaleLabelDiv .esriScalebarSecondNumber,
.jimu-widget-scalebar .scaleLabelDiv .esriScalebarFirstNumber,
.jimu-widget-scalebar .scaleLabelDiv .esriScalebarLabel{
white-space: nowrap;
font-size: 16px;
color: black;
padding-top: 2px;
Look in WebAppBuilderForArcGIS\server\apps\4\widgets\Scalebar\css
.esriScalebarSecondNumber {
left: 95%;
font-size: 20px;
color: red;
padding: 10px;}Should change the label
Nope, no change. Here is what I did:
jimu-rtl .jimu-widget-scalebar .scaleLabelDiv .esriScalebarLabel:first-child{
right: -3% !important;
left: auto !important;
.jimu-rtl .jimu-widget-scalebar .scaleLabelDiv .esriScalebarFirstNumber{
right: 45% !important;
left: auto;
.jimu-rtl .jimu-widget-scalebar .scaleLabelDiv .esriScalebarSecondNumber{
right: 95%;
left: auto;
font-size: 16px;
color: black;
padding: 10px;
position: relative;
top: -5px !important;
left: 0 !important;
Tim,
Are you sure you did it in the right folder as Rickey advised:
\WebAppBuilder\WAB2_0\server\apps\11\widgets\Scalebar\css
Notice not "Settings" in the path.
Yes, attached is a screenshot of the path.
Try copying in the css i posted above. See if that changes the text.
Tim,
Rickey is correct the css rule you are modifying is only for right to left languages and this does not apply to you. You sould use what Rickey provided or be a little more specific with your rule like:
font-size: 16px;
color: black;
padding: 10px;
Tim,
position: relative;
left: 0 !important;
font-size: 16px;
color: black;
padding-top: 2px;
Robert code worked for me too.
