Change WAB 2.7 widget icon size Launchpad theme
4907
7
01-31-2018 12:05 PM
CCWeedcontrol
How does one change the widget icons sizes on WAB 2.7?
I am using launchpad theme.
RobertScheitlin__GISP
CC,
   Well in that case, here is what you need:
In the [install dir]\server\apps\[app#]\themes\LaunchpadTheme\styles\default\css\launchpad.css
Go to the bottom of the file and add these two new rules:
.jimu-widget-onscreen-icon {
  width: 60px !important;
  height: 60px ! important;
.jimu-widget-onscreen-icon img {
  width: 32px;
  height: 32px;
  margin: 14px;
In the apps main config.json you will have to adjust the position paramaters for the onscreen widgets to add your desired spacing: (i.e. top and right)
        "position": {
          "right": 130,
          "top": 20,
          "relativeTo": "map"
CC,
   This the numbers used below are for doubling the icons size:
   In the [install dir]\server\apps\[app#]\themes\LaunchpadTheme\widgets\AnchorBarController\Widget.js
  var MIN_MARGIN = 16, ICON_SIZE = 80, ICON_IMG_SIZE = 40, BUTTON_SIZE = 60,
      NORMAL_MODE = 1, MOBILE_MODE = 2;
.jimu-anchorbar-iconitem .icon-item.dockable {
  margin-top: -45px;
.claro .jimu-anchorbar-iconitem .icon-item .icon {
  margin-top: 20px;
CCWeedcontrol
Thank you Robert but i meant the toggle buttons on the top right of the launchpad theme.
my apologies for forgetting that detail. Although this was useful i also wanted to make the bottom icon buttons bigger.
CC,
  width: 32px;
  height: 32px;
  margin: 14px;
        "position": {
          "right": 130,
          "top": 20,
          "relativeTo": "map"
CCWeedcontrol
sweet, thank you!
by Anonymous User
Not applicable
Robert Scheitlin, GISPthat worked nicely, in terms of anchor icon size!  Double size was a wee bit much though!
On a related note, is increasing the # of widgets in AnchorBarController as simple a matter? I'm on 2.8. It seems to be a proportion of the viewport width although I didn't see where that was coming from in its widget.js.
Kevin,
   It comes from several places in the widget.js. Lines like this:
domStyle.set(this.iconGroupNode, 'width',
              this.allConfigs.length * 2 * ICON_SIZE + 'px');
by Anonymous User
Not applicable
Hi Robert, I had figured..  I saw those and it seemed a bit involved.
So I discovered a simpler setting.
I changed ....
373    widgetWidth = Math.floor(mapBox.w / 2);
to divide by 1
373    widgetWidth = Math.floor(mapBox.w / 1);
..et voila.  Icons across the screen.  I actually notched it down to 1.5 and it worked nicely, took up most but not all of the bottom screen.
Hope this helps all.
