Change the highlight symbol for a selection
16806
29
08-12-2015 11:13 AM
NathanielRoth
Is it possible to change the symbol used to highlight a feature that has been clicked on (i.e. to show the popup info)? I can see and edit the symbols live through the debugger, but haven't been able to figure out where to make changes so that they'll be permanent.
On a related note, is there a preferred location for setting custom css properties to override existing ones?
I'm currently using Web AppBuilder-Developer's Edition 1.1.
RobertScheitlin__GISP
Should work just fine.
PatrickThorsell
I'm still getting the default after making the changes.
Will this work if pop-ups are disabled? I have simplefillsymbol in my requires.
map.infoWindow.resize(270, 316);
map.infoWindow.fillSymbol = new SimpleFillSymbol({
"type": "esriSFS",
"style": "esriSFSNull",
"color": [255,0,0,255],
"outline": {
"type": "esriSLS",
"style": "esriSLSSolid",
"width": 2
Partrick,
   No it will not work if popups are disabled. It is the popup that applies the highlight.
PatrickThorsell
So there is no way to control the symbology of the selected feature if popups are disabled? I was thinking it would be possible using a similar format as the Search Widget?
Patrick,
  So is it the search widget that is doing the highlighting?
PatrickThorsell
I am able to control the highlight symbology for the Search Widget using your instructions found here. I now need to do something similar for your Identify Widget, without using popups.
Patrick,
  Well that is a completely different subject then. The setting page for the Identify widget controls the symbology used for the identify widget.
PatrickThorsell
..Identify\setting\Setting.js?
Patrick Thorsell | GIS Analyst
Scott County | 200 4th Ave W Shakopee, MN 55379
(952) 496-8060 |[email protected]<mailto:[email protected]>
Patrick,
   The identify widget has a settings UI when you add/configure the widget. You can change the color of the selection there.
http://gis.calhouncounty.org/WAB/V2.4/widgets/Identify/help/identify_Help.htm#ESRI_STEP_20
PatrickThorsell
Boy, I made that way more difficult than it had to be☹ Thanks Robert!!
