Change extent and service for Overview Map
3089
11-05-2015 11:51 AM
LindseyStone
Does anyone know if you can change the max and min extent that the Overview Map displays at.  In my flex application,  I was able to set the max and min extent that the overview map zooms into and zooms out to.  In addition I was able to set it to display a completely different service than my default basemap.  This would be most useful with my WAB project I'm creating.  Is there a way with any additional coding?  I am using WAB 1.1 and Portal 10.3.1.
RobertScheitlin__GISP
Lindsey,
   No, as you probably noticed there is little to no configuration for this widget in WAB. You should submit these enhancement requests to the ideas site.
