Center Map via URL Parameters
7430
17
07-17-2015 08:58 AM
JayGeisen
I'm trying pass coordinates via the URL as shown here: Use URL parameters—Web AppBuilder for ArcGIS | ArcGIS
Nothing seems to happen though. Is this functionality not included in the developer edition? I can get the scale level to work, however.
JayGeisen
RobertScheitlin__GISP
Jay,
   As far as I know yes it should.
RickeyFight
My site works when adding   index.html?center=500000,5500000,102100  to the link.
Jay,
   So what is the WKID of your web map?
JayGeisen
My map is in State Plane (103046), Robert. I guess I assumed yours was too. Do you have a Web Mercator for testing purposes or something?
Jay,
   I have a Distributed GeoDatabase nightly replication process that converts my data into Web Mercator so that I can use ESRI basemaps. It's actually a simple process of following an esri white paper from making a FGDB that has your data in web mercator and then just having a nightly process that reconciles the child GDB with the parent, and you now have a web mercator version of your data that does not effect your original State Plane data.
34129 - Create a replica where the child replica data is in a different coordinate system than the p...
JayGeisen
Ahh, I see. That makes sense. Thanks for the link. So I guess I'll be awaiting the next release. Anybody know when that's due out?
First week in August Version 1.2 of Web AppBuilder Developer version.
