<div>
<label class="width70" for="FieldsCombo">Fields:</label>
<div data-dojo-attach-point="FieldsCombo" data-dojo-type="dijit/form/FilteringSelect" data-dojo-props="searchAttr:'name',intermediateChanges:true,placeHolder: 'Select Field'" class="dijit-form-FilteringSelect" style="width: 200px;height:30px;margin-Left: 51px;margin-top:5px;"></div>
</div>
this.SourceCombo.watch('displayedValue', function(property, oldValue, newValue) {
for(var k=0;k<layerInfoArray.length;k++)
if(layerInfoArray
break;
var requestHandle = esriRequest({
"url": "https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/"+k+"?f=pjson",
"content": {
"tags": "dog,us",
"tagmode": "all",
"format": "json"
"handeAs": "json",
"callbackParamName": "jsoncallback"
requestHandle.then(requestSucceeded, requestFailed);
function requestSucceeded(response, io){
var fields=(response["fields"]);
var FieldStore = new Memory({data: fields});
this.FieldsCombo.set('store', FieldStore);--------->this line produces errors
function requestFailed(error, io){
alert(dojoJson.toJson(error, true));
'cannot populate filteringselect
Resultent data from rest end point
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Nadir,
This is a similar issue as your last post. You have a scope issue "this" does not represent the widget in your requestSucceeded function because you have not hitched the scope.
requestHandle.then(lang.hitch(this, requestSucceeded), requestFailed);
Dear Robert,
I update the code as per your instructions but same error on same line.i use fieldsCombo with and without this key word.But same error on same place.
Nadir,
I will have to see your full widget code.
var _map, _FeatureLayer, _graphicsUtils, _Draw, _Graphic,_StatisticDefinition, _SimpleMarkerSymbol, _Color,
_FindTask,_FindParameters,_SimpleLineSymbol,_geometryEngine, _Query, _QueryTask, _SimpleFillSymbol,
_SimpleRenderer,_Point,selectedRegionCode;
var URLs = {
"RegionServiceUrl":"https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/2",
"GovServiceUrl":"https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/1",
"CentersServiceUrl":"https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/0",
"LocalitiesCentroidUrl": "https://localhost:6443/arcgis/rest/services/MOI/Tables/MapServer/"
var mapLayers = {RegionLayer:[],GovLayer:[],CentersLayer:[]},autoCompleteDataResult=[];
var selectedSymbol,slelctedPolygon,symbolRegion,symbolGov;
define(['dojo/_base/declare', 'jimu/BaseWidget','dojo/query',"dijit/form/Select", "esri/layers/FeatureLayer","esri/graphicsUtils",
"esri/toolbars/draw", "esri/graphic","esri/tasks/StatisticDefinition","esri/symbols/SimpleMarkerSymbol",
"esri/Color","esri/tasks/FindTask", "esri/tasks/FindParameters","esri/symbols/SimpleLineSymbol",
"esri/geometry/geometryEngine","esri/tasks/query",'jimu/LayerInfos/LayerInfos',"esri/tasks/QueryTask",
"esri/symbols/SimpleFillSymbol","esri/renderers/SimpleRenderer", "esri/geometry/Point",'dojo/store/Memory',
"dijit/_WidgetsInTemplateMixin",'dojo/_base/lang',"dojo/data/ObjectStore","esri/request", "dojo/_base/json",'dojo/on',"dojo/dom",
"dijit/form/FilteringSelect",
'jimu/loaderplugins/jquery-loader!./JS/jquery.min.js,./JS/jquery-ui.min.js,./JS/bootstrap.min.js,./JS/jsgrid.js,./JS/jsgrid.min.js'
function(declare,BaseWidget,query,Select,FeatureLayer,graphicsUtils,Draw,Graphic,StatisticDefinition,SimpleMarkerSymbol,
Color,FindTask,FindParameters, SimpleLineSymbol,geometryEngine,Query,LayerInfos ,QueryTask,SimpleFillSymbol,
SimpleRenderer,Point,Memory,_WidgetsInTemplateMixin,lang,ObjectStore,esriRequest,dojoJson,on,dom) {
//To create a widget, you need to derive from BaseWidget.
return declare([BaseWidget, _WidgetsInTemplateMixin], {
// Custom widget code goes here
baseClass: 'jimu-widget-SpatialSearchQuery',
postCreate: function() {
this.inherited(arguments);
console.log('postCreate');
startup: function() {
var panel = this.getPanel();
panel.position.width = 260;
panel.position.height = 300;
panel.setPosition(panel.position);
panel.panelManager.normalizePanel(panel);
_map = this.map;
_FeatureLayer = FeatureLayer;
_graphicsUtils = graphicsUtils;
_Draw = Draw;
_Graphic = Graphic;
_StatisticDefinition = StatisticDefinition;
_SimpleMarkerSymbol = SimpleMarkerSymbol;
_Color = Color;
_FindTask = FindTask;
_FindParameters = FindParameters;
_SimpleLineSymbol = SimpleLineSymbol;
_geometryEngine = geometryEngine;
_Query = Query;
_QueryTask = QueryTask;
_SimpleFillSymbol = SimpleFillSymbol;
_SimpleRenderer = SimpleRenderer;
_Point = Point;
var layerInfoArray=[];
var lyrArray=[];
if (this.map.itemId) {
LayerInfos.getInstance(this.map, this.map.itemInfo)
.then(lang.hitch(this, function(operLayerInfos) {
this.operLayerInfos = operLayerInfos;
this.operLayerInfos.traversal(lang.hitch(this, function(layerInfo) {
layerInfoArray.push(layerInfo);
for(var k=1;k<layerInfoArray.length;k++)
lyrArray.push({"ID":layerInfoArray
var myStore = new Memory({data: lyrArray});
this.SourceCombo.set('store', myStore);
this.TargetCombo.set('store', myStore);
//this.SourceCombo.on('change', lang.hitch(this, function(){
// console.log("Hello");
// alert("ffff");
//_getAllFields("Hello");
if(layerInfoArray
break;
"content": {
"tags": "dog,us",
"tagmode": "all",
"format": "json"
"handeAs": "json",
//var os = new ObjectStore({ objectStore: FieldStore });
_getAllFields:function (strLayerName,lyrInfoArray){
alert("In side"+strLayerName);
if(layerInfoArray
break;
onOpen: function(){
console.log('onOpen');
onClose: function(){
console.log('onClose');
// onMinimize: function(){
// console.log('onMinimize');
// onMaximize: function(){
// console.log('onMaximize');
// onSignIn: function(credential){
// /* jshint unused:false*/
// console.log('onSignIn');
// onSignOut: function(){
// console.log('onSignOut');
// onPositionChange: function(){
// console.log('onPositionChange');
// resize: function(){
// console.log('resize');
//methods to communication between widgets:
<div>
<div >
<label class="width70" for="SourceCombo" style="margin-top:-20px">Source Layer:</label>
<div data-dojo-attach-point="SourceCombo" data-dojo-type="dijit/form/FilteringSelect" data-dojo-props="searchAttr:'Title',intermediateChanges:true,placeHolder: 'Select Source Layer'" class="dijit-form-FilteringSelect" style="width: 360px;height:30px;margin-Left: 10px;margin-top:-10px;"></div>
</div>
<div>
<label class="width70" for="TargetCombo">Target Layer:</label>
<div data-dojo-attach-point="TargetCombo" data-dojo-type="dijit/form/FilteringSelect" data-dojo-props="searchAttr:'Title',intermediateChanges:true,placeHolder: 'Select target Layer'" class="dijit-form-FilteringSelect" style="width: 360px;height:30px;margin-Left: 14px;margin-top:1px;"></div>
</div>
<div>
</div>
</div>
Nadir,
OK, I see your issue now. Your requestSucceeded function is inside the this.SourceCombo.watch('displayedValue', function. So you need:
this.SourceCombo.watch('displayedValue', lang.hitch(this, function(property, oldValue, newValue) {
for (var k = 0; k < layerInfoArray.length; k++) {
if (layerInfoArray[k].title == newValue)
break;
"url": "https://localhost:6443/arcgis/rest/services/BaseMap/MapServer/" + k + "?f=pjson",
"content": {
"tags": "dog,us",
"tagmode": "all",
"format": "json"
"handeAs": "json",
function requestSucceeded(response, io) {
var fields = (response["fields"]);
data: fields
function requestFailed(error, io) {
