can WAB built-in and WAB dev be installed on same Portal server?
1445
05-25-2016 10:53 AM
TomGushue
I was wondering if both the standard WAB and the separate WAB for Developers can exist on the same Portal server.  I'd like to get some quick web apps out through our portal using the built-in WAB, but will most likely begin building custom WAB widgets in the near future, and so will need the WAB for Developers to do this.
Any ideas or help with this is greatly appreciated.
-- Tom
RobertScheitlin__GISP
Tom,
  WAB Dev is not intended to be installed on a server. The developer edition is to be installed on a workstation where someone will be configuring apps and then that app is downloaded and deployed to a web server.
