Can the query widget use temp field names created with arcade for pop-ups on a webmap
1461
04-13-2020 04:48 PM
YulBrav
I created a webmap using a rest map service. I used a couple of arcade expressions to  calculate values for the pop-ups. Those calculated values show up in the attribute table under a field named after the arcade expression. When I create a web app I can't find those fields when I try to build a query. Is it possible to query the values generated by the arcade expressions or just the original fields in the table?
Thank you
XanderBakker
Esri Esteemed Contributor
Hi Yul Brav ,
Unfortunately, when you add arcade expressions to your pop-up, those "virtual fields" are not available in the widgets of the WAB. To be able to use them, you will need to add fields and calculate the fields using the same arcade expression you already have.
XanderBakker
Hi Yul Brav ,
YulBrav
Thank you Xander Bakker.
