Can not view tabular map service
1453
10-05-2023 01:35 AM
yockee
I publish a table that stored in Postgresql Geodb. The service is successfully published.
The steps to publish are:
1. Add new tabular data
2. Right click it then Sharing -> Share As Table
3. The product has address: https://myserver/server/rest/services/Hosted/test_tabular_latest_3Days/FeatureServer/0
I can access the URL just fine. But, the problem is I can not view the tabular data when I make Web Map application. I have tried: Serial Chart, Tables, Gauge, List... practically everything. Why ? There is a warning sign: "Can Not access Data". See the pic below:
If its an ordinary Map Service, the data can be displayed fine.
Need help in overcoming the problem.
Thanks
Thanks for the help
Tags (1)
BrianLeroux
Are you able to query the data using the query rest endpoint of that service? That would be my fist check just to make sure the data is being served properly.
I use tables for my custom widgets to populate drop down fields but never try to add the table directly to a pre-existing widget. Possibly not supported but I am not sure.
yockee
I can query just fine. all results come out.
Actually, I want to make Line Chart using this table and displayed on the web app. I just want to display the table without map
yockee
Finally I am able to see the tabular data. The keys are:
- the table must include ObjectID
- do not apply Definition Query in ArcGIS Pro prior to publishing
Now another problem: the table seems static. Or is it meant to be static ?
