Can I customize the LayerList widget to add non-interactive descriptive text lines between layers listed.
9579
32
01-19-2018 12:48 PM
BenjaminGrover
I've seen some talk about this in other discussions, but no solid solutions.  Where would one need to add code to insert text lines between layers in the LayerList widget?  I'm wanting to add some descriptive text, smaller font, bolded, and in red, below a few layers listed in the Widget. Can this be done??
RobertScheitlin__GISP
Brain,
  The only thing I can think of is some syntax error in the style.css...?
BrianDudek1
hmmmm.  the height property works, but not color or font-size.  :shrug:
.jimu-widget-layerList .desc{
  height: 10px;  /* Working- spacing between former and latter layer */
  color: #00ffff;  /* Not working */
  font-size: 11px; /* Not working */
I am not too worried about it, since I was just exploring some possible WAB functionality edits, but was curious anyway.
Brian,
   OK, if part of your css rule works but other properties do not then there is a css rule elsewhere that has higher specificity then your rule. You can force the color by adding !important
  color: #00ffff !important;  /* Working */
  font-size: 11px !important; /* Working */
BrianDudek1
Good to know good to know.  Doesn't do anything in this situation though.  I can change the color obviously with HTML in the innerHTML part of divLabel. Anyways, I need to start reading more and practicing. 😃
BenjaminGrover
I also have web app builder. 2.0 developer edition, I haven't take then time to upgrade.  Just hit me that the LayerList widget has seen some changes in more recent releases, could this be my issue?
That is the most likely issue (version). The code I provide was for 2.6.
BenjaminGrover
Downloading 2.7 right now. Do you suspect they are the same?
very likely.
BenjaminGrover
version 2.7 seemed to make no difference. I got the same error.
Ben,
   Hmm.. you must have introduced a syntax error in the widgets code then.
