Call a function from an ArcGIS Online Popup
2313
09-15-2016 01:46 PM
ChristopherSchreiber
Hello all,
Is it possible to call a function from an ArcGIS Online Popup? I would like to have the title of the popup direct to another part of our web based app. The URL contains a security token that changes so I can't just use an href and link it that way. We have a function that will take a field value from the layer and use it to determine what page in the application that you need to go to. We have tried using href= "javascript:functionName({value from layer}) and an onclick event. These were added inside the popup configuration area on AGOL.
The "javascript:" and onclick events were removed when the map was saved.
The web map displays inside our web application using an app created with Esri's Web AppBuilder. I would really like to avoid trying to customize popups from web AppBuilder but I may not have a choice.
Has anyone been able to do this?
Thanks!
Tags (3)
RobertScheitlin__GISP
Chris,
You do not have any other option, that I am aware of.
Christopher,
   Customizing your app like that will require the use of WAB Dev. There is not a way to do this in AGOL WAB that I am aware of.
Robert,
I have WAB dev edition. That is what I am using to create the web apps.
Chris
Chris,
Robert,
I was afraid of that, but I appreciate the help!
One thing we may end up doing is adding the request to an image as a link and then having the image show on the popup.
Thanks again!
Chris
