Bulk Attribute Editor not showing all fields when setting up widget
1515
08-02-2022 08:04 AM
JonJones1
Hello all,
I have an issue where the bulk attribute editor does not show all available fields for a layer when setting up the widget. I am only trying to bulk edit the attributes in one layer and I see about 5 fields out of the 20 different fields this layer has.  Any thoughts?
Savannah2019
In your map, not the app, are the other fields editable in the pop-up? If they're not editable in the pop-up they won't show up in the batch attribute editor as an option.
Savannah2019
JonJones1
Your answer fixed my issue.  I had to go into the classic map viewer and make the fields selectable in pop-ups.  The original map was first manipulated in the classic map viewer, I could never get it fixed in the new/current map viewer.
