Attribute Table no longer working since update
1193
07-03-2024 01:15 PM
ericsamson_tract
Hey all,
Wondering if anyone else has been experiencing this. Both in my custom WAB applications and ones made from ArcGIS Online, attribute tables are not loading and I am met with a loading screen:
The error that gets sent to the console says:
TypeError: Cannot read properties of undefined (reading 'replace')
at Object.<anonymous> (LayerInfoForDefaultService.js?wab_dv=2.30:426:48)
at init.js:65:207
at r (init.js:110:277)
at q (init.js:110:203)
at a.resolve (init.js:112:280)
at Object.setResponse (RequestBuffer.js?wab_dv=2.30:120:24)
at Object.<anonymous> (LayerInfoForMapService.js?wab_dv=2.30:705:34)
at init.js:65:207
at Object.traversal (LayerInfo.js?wab_dv=2.30:156:10)
at Object.traversal (LayerInfo.js?wab_dv=2.30:161:30) "TypeError: Cannot read properties of undefined (reading 'replace')\n at Object.<anonymous> (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfoForDefaultService.js?wab_dv=2.30:426:48)\n at https://js.arcgis.com/3.46/init.js:65:207\n at r (https://js.arcgis.com/3.46/init.js:110:277)\n at q (https://js.arcgis.com/3.46/init.js:110:203)\n at a.resolve (https://js.arcgis.com/3.46/init.js:112:280)\n at Object.setResponse (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/RequestBuffer.js?wab_dv=2.30:120:24)\n at Object.<anonymous> (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfoForMapService.js?wab_dv=2.30:705:34)\n at https://js.arcgis.com/3.46/init.js:65:207\n at Object.traversal (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfo.js?wab_dv=2.30:156:10)\n at Object.traversal (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfo.js?wab_dv=2.30:161:30)\n ----------------------------------------\n rejected at c (https://js.arcgis.com/3.46/init.js:111:174)\n at r (https://js.arcgis.com/3.46/init.js:110:436)\n at q (https://js.arcgis.com/3.46/init.js:110:203)\n at a.resolve (https://js.arcgis.com/3.46/init.js:112:280)\n at Object.setResponse (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/RequestBuffer.js?wab_dv=2.30:120:24)\n at Object.<anonymous> (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfoForMapService.js?wab_dv=2.30:705:34)\n at https://js.arcgis.com/3.46/init.js:65:207\n at Object.traversal (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfo.js?wab_dv=2.30:156:10)\n at Object.traversal (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfo.js?wab_dv=2.30:161:30)\n at Object.<anonymous> (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfoForMapService.js?wab_dv=2.30:694:16)\n ----------------------------------------\nError\n at then.e.then (https://js.arcgis.com/3.46/init.js:113:97)\n at Object.getLayerType (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfoForDefaultService.js?wab_dv=2.30:424:38)\n at Object.getSupportTableInfo (https://tract-lt14:3344/webappbuilder/apps/2/jimu.js/LayerInfos/LayerInfoForDefaultService.js?wab_dv=2.30:453:12)\n at https://tract-lt14:3344/webappbuilder/apps/2/widgets/AttributeTable/utils.js?wab_dv=2.30:365:29\n at Object.forEach (https://js.arcgis.com/3.46/init.js:73:69)\n at Object.<anonymous> (https://tract-lt14:3344/webappbuilder/apps/2/widgets/AttributeTable/utils.js?wab_dv=2.30:364:13)\n at https://js.arcgis.com/3.46/init.js:65:207\n at r (https://js.arcgis.com/3.46/init.js:110:277)\n at then.e.then (https://js.arcgis.com/3.46/init.js:113:152)\n at exports.readConfigLayerInfosFromMap (https://tract-lt14:3344/webappbuilder/apps/2/widgets/AttributeTable/utils.js?wab_dv=2.30:362:6)"
ericsamson_tract
For developer version people, I found a solution by altering the LayerInfoForDefaultService.js file located in:
You have to change the following function:
getLayerType: function() {
  var def = new Deferred();
  // if this.layerInfo is groupLayerInfo
  if(this.getSubLayers().length > 0) {
    def.resolve("GroupLayer");
  } else {
    this._getServiceDefinition().then(lang.hitch(this, function(serviceDefinition) {
      if (serviceDefinition) {
        def.resolve(serviceDefinition.type.replace(/\ /g, ''));
      } else {
        def.resolve(null);
    }), function() {
      def.resolve(null);
  return def;
To:
  } else {
      if (serviceDefinition && serviceDefinition.type) {
      } else {
        console.warn('Service definition or type is undefined');
        def.resolve(null);
    }), function(error) {
      console.error('Error getting service definition:', error);
      def.resolve(null);
  return def;
The servicedefinition is undefined when the code tries to access its type property. My fix just ignores it, it is still have trouble finding the servicedefinition when the attribute table or the select widgets are opened. But this allows them to work for now.
ericsamson_tract
  } else {
      } else {
        def.resolve(null);
    }), function() {
      def.resolve(null);
  return def;
To:
  } else {
      } else {
        def.resolve(null);
      def.resolve(null);
  return def;
