ArcGIS Developer Edition v2.7 issue
1925
01-26-2018 01:39 PM
CCWeedcontrol
I am having issues with WAB 2.7. After i created a Application and save it and go back the WAB main Apps page then go back into the App to edit it the App just hangs it doesn't open the App up to edit. I have to close out of web browser window and manually close out of the WAB 2.7 startup.bat window in order for me to go back into that App and edit it.
Anyone else having this issue? i have uninstalled and reinstalled but i have the same issue.
RobertScheitlin__GISP
I am not having this issue. Does your browsers console give you any errors?
CCWeedcontrol
I just tried it in Chrome and i am able to get into the app and edit it.
In firefox in console i get.
jimu.js init...
main.js:199:7
Timer “Load Config” already exists.
ConfigLoader.js:86:7
hccss: exception detecting high-contrast mode, document is likely hidden: TypeError: e is null
init.js:340:101
Use of getAttributeNode() is deprecated. Use getAttribute() instead.
init.js:159:263
Exception { name: "NS_ERROR_NOT_INITIALIZED", message: "", result: 3253927937, filename: "https://jsdev.arcgis.com/3.23/init.js", lineNumber: 114, columnNumber: 0, data: null, stack: "q@https://jsdev.arcgis.com/3.23/init.js:114:237\nc@https://jsdev.arcgis.com/3.23/init.js:103:350\ndojo/_base/Deferred/</b.Deferred/this.then@https://jsdev.arcgis.com/3.23/init.js:105:463\nalways@https://jsdev.arcgis.com/3.23/init.js:112:429\nD@https://jsdev.arcgis.com/3.23/init.js:1021:410\nra@https://jsdev.arcgis.com/3.23/init.js:2484:37\nIa/<@https://jsdev.arcgis.com/3.23/init.js:2493:148\nforEach@https://jsdev.arcgis.com/3.23/init.js:71:19\nIa@https://jsdev.arcgis.com/3.23/init.js:2493:54\nNa@https://jsdev.arcgis.com/3.23/init.js:2490:26\nJ/</</<@https://jsdev.arcgis.com/3.23/init.js:2521:302\nc@https://jsdev.arcgis.com/3.23/init.js:103:393\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nI/<@https://jsdev.arcgis.com/3.23/init.js:2447:108\nc@https://jsdev.arcgis.com/3.23/init.js:103:393\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nd@https://jsdev.arcgis.com/3.23/init.js:2527:85\ndojo/DeferredList/</n.DeferredList/</<@https://jsdev.arcgis.com/3.23/init.js:2527:136\nc@https://jsdev.arcgis.com/3.23/init.js:103:393\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nc@https://jsdev.arcgis.com/3.23/init.js:104:61\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nc@https://jsdev.arcgis.com/3.23/init.js:104:61\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\ng/<@https://jsdev.arcgis.com/3.23/init.js:1016:187\nc@https://jsdev.arcgis.com/3.23/init.js:103:393\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nc@https://jsdev.arcgis.com/3.23/init.js:104:163\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nc@https://jsdev.arcgis.com/3.23/init.js:104:163\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nc@https://jsdev.arcgis.com/3.23/init.js:104:61\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\nc@https://jsdev.arcgis.com/3.23/init.js:104:61\nd@https://jsdev.arcgis.com/3.23/init.js:103:182\ndojo/_base/Deferred/</b.Deferred/this.callback@https://jsdev.arcgis.com/3.23/init.js:105:10\ndojo/_base/xhr/</b.xhr/<@https://jsdev.arcgis.com/3.23/init.js:92:116\nh@https://jsdev.arcgis.com/3.23/init.js:107:277\nq@https://jsdev.arcgis.com/3.23/init.js:107:203\nd/this.resolve@https://jsdev.arcgis.com/3.23/init.js:109:280\na@https://jsdev.arcgis.com/3.23/init.js:108:146\nh@https://jsdev.arcgis.com/3.23/init.js:107:417\nq@https://jsdev.arcgis.com/3.23/init.js:107:203\nd/this.resolve@https://jsdev.arcgis.com/3.23/init.js:109:280\na@https://jsdev.arcgis.com/3.23/init.js:108:146\nh@https://jsdev.arcgis.com/3.23/init.js:107:450\nq@https://jsdev.arcgis.com/3.23/init.js:107:203\nd/this.resolve@https://jsdev.arcgis.com/3.23/init.js:109:280\na@https://jsdev.arcgis.com/3.23/init.js:108:146\nh@https://jsdev.arcgis.com/3.23/init.js:107:417\nq@https://jsdev.arcgis.com/3.23/init.js:107:203\nd/this.resolve@https://jsdev.arcgis.com/3.23/init.js:109:280\ng@https://jsdev.arcgis.com/3.23/init.js:139:97\nf@https://jsdev.arcgis.com/3.23/init.js:143:369\n" }
init.js:114:10
I just tested in the latest version of FireFox and still can not see the issue you are seeing.
CCWeedcontrol
Ok, I believed i figured it out,  I think something was wrong with the ArcGIS Online map i was using, i might be corrupted. So I created a new map, then I created a new app and used the new map and it seems to work.
Sorry about that.
