AppBuilder Invalid redirect_uri
37778
31
01-14-2015 01:17 PM
SarahLinden
This is my first time using web app builder. I got to the point where I registered my apps URL properly, but must have used the wrong App ID....... I can't seem to get back to where I re-enter the appropriate app ID and am instead taken to a page that is blank and just says invalid redirect_uri
Anyone experience the same issue? Help! What should I do???
Tags (1)
RebeccaStrauch__GISP
That seems to be the consensus.  Glad it worked for you.
JC-220
Using both http and https address did it for me. Thanks to you I still have a little bit of hair left.
marcostenorio
change the file serve/signininfo.json
DavidWasserman
As Marcos said, you chang the App ID in signininfo.json or actually delete it and restart app builder.
It is explained on the FAQs here too: FAQs—Web AppBuilder for ArcGIS (Developer Edition) | ArcGIS for Developers
David Wasserman, AICP
AaronKreag2
I just spent 2 hours messing with this.  Everywhere that is says localhost I had to go through the process from scratch and use my fully qualified names like http://servername.domainname.local:3344/webappbuilder
I did this during the web app builder registration process on my AGO account and in the redirect URI screen with http and https.  This is not well documented at all.
JosiahCorona2
I know this is a very late response but I had this issue this morning and I fixed it quite simply!
Go to your C:\..........\arcgis-web-appbuilder-2.0\WebAppBuilderForArcGIS\server
Then open your signinginfo.json file
there it gives you the option to change URL and App Id if need be.
GeoffreyWest
What is the solution for this for an app deployed on a local server? I have downloaded my application and configured it on IIS. When I register the app, what do the server:[port] refer to to redirect local URI?  Also what does the URL refer to? Is this the URL where the app is being accessed from?      I am receiving an Invalid URI error.
GeoffreyWest
Rebecca,
This isn't the Developer Edition.  I have downloaded the my app from AGOL but am receiving a URI error.
gangatrial
Hi, I was struggling with this 'Invalid redirect_uri with error 400'. After 30 minutes of all try and error, did 2 things. of this, which one solved I am not sure. 1. Changed my default browser from IE  11 to Google Chrome v 49.0 2. While providing the redirect uri;s included domain name. ex: https://.:3344 and it Worked !
