Add to Current Selection WebApp Builder
1619
05-15-2019 06:34 AM
SteveJavins
I'm wondering if there is a way to add to a current selection using the Select widget in WebApp Builder.
If not, can WebApp Builder Developer edition be used to customize the Select widget to do so? Can that customized widget be used with a WAB app that uses a predefined theme?
RobertScheitlin__GISP
Steve,
Not really. The widget does have a _getSelectableLayers method that will allow you to get the layers and then you can call layers getselectedfeatures method.
Yes as long as you are using this custom widget in Portal or WAB Dev edition (custom widgets are not supported in AGOL WAB Apps).
Steve,
SteveJavins
Thank you.
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
