Add Custom Themes in Enterprise
1127
03-23-2022 12:39 AM
maha-se
Greetings!
Is it possible to add WAB custom themes in ArcGIS Enterprise the same way you add custom widgets?
If not, is there any other way to do it?
I have created a custom theme in WAB Developer Edition 2.23 and follow this guide
https://enterprise.arcgis.com/en/web-appbuilder/latest/create-apps/add-custom-widgets.htm
I pointed to the theme manifest.json file, but it only add it as a widget instead of a theme that can be used within the organisation.
kreed
Hi @maha-se,
Did you ever get this figured out? I am trying to do the same thing, but I can't seem to find a solution.
