Add custom text element to print layout in print widget
9409
01-10-2021 06:21 AM
MHasan
Hello everyone.
I have been trying to create a printing service from tools published from ArcGIS Pro using the following tutorial:
Share custom layouts for printing from ArcGIS Pro—ArcGIS Server | Documentation for ArcGIS Enterpris...
I want to add a custom text element and let the user enter the text value in the print widget.
The tutorial indicates that :
"If you want to insert a custom text element, add a text element and embed the element's name in a set of open and closed curly braces, such as {parcel-id}."
But it doesn't tell how and where to embed the element name.
LongDinh
Hi MHasan,
I was also perplexed by this vague description as well. Luckily I found the solution by looking at the default installation templates.
The name of the element is the Table of Contents when in Layout mode. Adding a open and closed curly bracket will add the element to the Print Layout Template JSON's "customTextElements" array.
Below is a screen capture of the "Get Layout Templates Info" which has successfully added the "{VeryCustomElementName}" dynamic element to the print template
LongDinh
Hi MHasan,
MHasan
Thank you very much @LongDinh
It's really easy but it wasn't obvious from the documentation.
BugPie
The screen shot was the winning piece. Thanks for sharing that visual aid. Man, I've been stuck on this one... no more!
DavidlMason
That was very simple, thanks.
Now is there a simple way to add a legend also? I tried the curly brackets around that, but that would've been too easy.
