404 config.json error for server deployment of WebAppBuilder Application?
9337
15
07-14-2016 03:38 PM
GeoffreyWest
I am reeving  a 404 error that my config.json cannot be found, I have added the JSON mime type to my IIS configuration at the site and server levels and have restarted IIS.  This error appears as so in my console  with other errors which I think are caused by the initial 404 of the config.json.  What other steps can be taken to remedy this?  Additionally when I hit the index.html I receive  an "Unexpected token < in JSON at position 0" error
GET http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/css/fonts/c4352a95-7a41-48c1-8...
main.js?wab_dv=2.1:1521 jimu.js init...
init.js:140 GET http://gisdev01/LifeSupportApplication/LifeSupportApplication/config.json?wab_dv=2.1 404 (Not Found)h @ init.js:140_tryLoadConfig @ main.js?wab_dv=2.1:236loadConfig @ main.js?wab_dv=2.1:227loadConfig @ main.js?wab_dv=2.1:11f.initApp @ main.js?wab_dv=2.1:1522(anonymous function) @ init.js:200ia @ init.js:28(anonymous function) @ init.js:28ja @ init.js:28ga @ init.js:28b @ init.js:29f @ init.js:151d @ init.js:152
init.js:113 TypeError: Cannot read property 'portalUrl' of undefined(…) "TypeError: Cannot read property 'portalUrl' of undefined
    at _addDefaultPortalUrl (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:32:492)
    at _addDefaultValues (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:31:416)
    at .<anonymous> (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:11:456)
    at http://js.arcgis.com/3.17/init.js:63:209
    at h (http://js.arcgis.com/3.17/init.js:107:279)
    at k (http://js.arcgis.com/3.17/init.js:107:205)
    at g.resolve (http://js.arcgis.com/3.17/init.js:109:280)
    at a (http://js.arcgis.com/3.17/init.js:108:148)
    at h (http://js.arcgis.com/3.17/init.js:107:419)
    rejected at a (http://js.arcgis.com/3.17/init.js:108:174)
    at h (http://js.arcgis.com/3.17/init.js:107:438)
    at g.w.reject (http://js.arcgis.com/3.17/init.js:109:488)
    at h (http://js.arcgis.com/3.17/init.js:107:452)
Error
    at then.c.then (http://js.arcgis.com/3.17/init.js:110:97)
    at loadConfig (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:11:361)
    at Object.f.initApp (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:1522:55)
    at http://gisdev01/LifeSupportApplication/LifeSupportApplication/init.js:200:24
    at ia (http://js.arcgis.com/3.17/init.js:28:3)
    at http://js.arcgis.com/3.17/init.js:28:256
    at ja (http://js.arcgis.com/3.17/init.js:28:125)
    at ga (http://js.arcgis.com/3.17/init.js:28:198)
    at b (http://js.arcgis.com/3.17/init.js:29:177)
    at f (http://js.arcgis.com/3.17/init.js:151:195)"
GeoffreyWest
1. I did download app director and put it in my Inetpub folder. Configured
IIS with .json and application/json MIME settings
2. This is not publicly available, but is available on the organization
network, i.e. I can hit GISDEV01 from any machine that is on this network.
(However the app via AGOL is public)
3.I have the app in a folder called LifeSupportApplication and the
index.html is in there.
On Fri, Jul 15, 2016 at 8:36 AM, Robert Scheitlin, GISP <[email protected]>
RobertScheitlin__GISP
Geoffery,
OK, so the url http: //gisdev01/LifeSupportApplication/LifeSupportApplication/config.json?wab_dv=2.1 seems to be the issue.
you state:
So if that is the case the url you should be using is:
http://gisdev01/LifeSupportApplication/config.json?wab_dv=2.1
not
GeoffreyWest
I was able to successfully hit the JSON from my client; where is it
supposed to be changed in my JS or HTML? Thanks for your help Robert. Is
there a better way to configure this so I don't encounter this issue again?
On Fri, Jul 15, 2016 at 8:46 AM, Robert Scheitlin, GISP <[email protected]>
Geoffery,
If you just use http://gisdev01/LifeSupportApplication/​in your browsers url does it not work?
GeoffreyWest
It does work; I was able to figure it out; I had to redirect the file in
IIS to the correct URL.
On Fri, Jul 15, 2016 at 9:29 AM, Robert Scheitlin, GISP <[email protected]>
Geoffery,
  Great don't forget to mark this thread as answered.
