404 config.json error for server deployment of WebAppBuilder Application?
9351
15
07-14-2016 03:38 PM
GeoffreyWest
I am reeving  a 404 error that my config.json cannot be found, I have added the JSON mime type to my IIS configuration at the site and server levels and have restarted IIS.  This error appears as so in my console  with other errors which I think are caused by the initial 404 of the config.json.  What other steps can be taken to remedy this?  Additionally when I hit the index.html I receive  an "Unexpected token < in JSON at position 0" error
GET http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/css/fonts/c4352a95-7a41-48c1-8...
main.js?wab_dv=2.1:1521 jimu.js init...
init.js:140 GET http://gisdev01/LifeSupportApplication/LifeSupportApplication/config.json?wab_dv=2.1 404 (Not Found)h @ init.js:140_tryLoadConfig @ main.js?wab_dv=2.1:236loadConfig @ main.js?wab_dv=2.1:227loadConfig @ main.js?wab_dv=2.1:11f.initApp @ main.js?wab_dv=2.1:1522(anonymous function) @ init.js:200ia @ init.js:28(anonymous function) @ init.js:28ja @ init.js:28ga @ init.js:28b @ init.js:29f @ init.js:151d @ init.js:152
init.js:113 TypeError: Cannot read property 'portalUrl' of undefined(…) "TypeError: Cannot read property 'portalUrl' of undefined
    at _addDefaultPortalUrl (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:32:492)
    at _addDefaultValues (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:31:416)
    at .<anonymous> (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:11:456)
    at http://js.arcgis.com/3.17/init.js:63:209
    at h (http://js.arcgis.com/3.17/init.js:107:279)
    at k (http://js.arcgis.com/3.17/init.js:107:205)
    at g.resolve (http://js.arcgis.com/3.17/init.js:109:280)
    at a (http://js.arcgis.com/3.17/init.js:108:148)
    at h (http://js.arcgis.com/3.17/init.js:107:419)
    rejected at a (http://js.arcgis.com/3.17/init.js:108:174)
    at h (http://js.arcgis.com/3.17/init.js:107:438)
    at g.w.reject (http://js.arcgis.com/3.17/init.js:109:488)
    at h (http://js.arcgis.com/3.17/init.js:107:452)
Error
    at then.c.then (http://js.arcgis.com/3.17/init.js:110:97)
    at loadConfig (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:11:361)
    at Object.f.initApp (http://gisdev01/LifeSupportApplication/LifeSupportApplication/jimu.js/main.js?wab_dv=2.1:1522:55)
    at http://gisdev01/LifeSupportApplication/LifeSupportApplication/init.js:200:24
    at ia (http://js.arcgis.com/3.17/init.js:28:3)
    at http://js.arcgis.com/3.17/init.js:28:256
    at ja (http://js.arcgis.com/3.17/init.js:28:125)
    at ga (http://js.arcgis.com/3.17/init.js:28:198)
    at b (http://js.arcgis.com/3.17/init.js:29:177)
    at f (http://js.arcgis.com/3.17/init.js:151:195)"
RobertScheitlin__GISP
Geoffery,
OK, so the url http: //gisdev01/LifeSupportApplication/LifeSupportApplication/config.json?wab_dv=2.1 seems to be the issue.
you state:
I have the app in a folder called LifeSupportApplication and the
index.html is in there.
So if that is the case the url you should be using is:
http://gisdev01/LifeSupportApplication/config.json?wab_dv=2.1
not
Geoffery,
  Sounds like you have a syntax error in your config.json. Can you zip and attach it using the advanced editor?
GeoffreyWest
Hi Robert,
I have attached my .json.
Geoffery,
  I can find nothing wrong with your config.json. The main thing I do see is that you have "portalUrl": "your true orgs address" in the map object and "portalUrl": "http://myorg.maps.arcgis.com", in the main portion. In all my apps they are the same url. Another thing that looks odd is "icon": "widgets/MyLocation/images/icon.png?wab_dv=2.1",. What did you use to create this app (WAB Dev or AGOL)?
GeoffreyWest
Hi Robert,
Thanks for your insight; I used AGOL to create the app.  I was using my.org.maps.arcgis as a placeholder bc I didn't want the org address to be public, but I mistakenly left that in there. Do you mind removing it from your message?
OK, Have you tried to just bring up the config.json for your site in the url?
http://gis.calhouncounty.org/WAB/V2.0/widgets/eSearch/config.json
GeoffreyWest
I just tried, same error, I am using IIS6. So something is not correct on my configuration, do I need a proxy as suggested?
Use proxy—Web AppBuilder for ArcGIS | ArcGIS
Geoffery,
  1. Is this a public site yet?
  2. Can you access any other files using the url i.e. http://gis.calhouncounty.org/WAB/V2.0/widgets/eSearch/images/loading.gif
GeoffreyWest
The site should be made public via arcgis online, correct?
Error below
Geoffery,
  I think you are a little confused.
  1. When you created the app on AGOL did you download/export the site from AGOL and then host the site on your IIS6 machine?
  2. If so then NO it would not be publicly accessible unless your IIS machine is.
  3. With a url like http: //gisdev01/LifeSupportApplication/LifeSupportApplication/... you are only hosting locally.
  4. Are you sure that http: //gisdev01/LifeSupportApplication/LifeSupportApplication/ is correct for the url?
  5. Do you have the app in a folder called LifeSupportApplication and that folder has a child folder called LifeSupportApplication in it?
