WAB Table Widget Synch Layer Vis
1542
06-10-2020 10:38 AM
Status: Open
ZorbaConlen1
Hi. WAB table widget has a config option to "Synchronize with layer visibilities" option which is nice, but it does not work how one would expect. The problem is that if one has group layers like shown in the screenshot below, sub-layers that are not visible on the map still show up in the table widget. For example, sewer inlets is not visible because the parent group in unchecked, yet it would still show in the table widget.
So, the idea is to make this widget smarter so that it honors actual layer visibility on the map.
Thanks
WAB layer list
3 Comments
LanceKirby2
Having the same issue. Did you ever figure out a resolution??? @ZorbaConlen1
ZorbaConlen1
Hi Lance. No, have not. I think esri would have to modify the widget and they are more focused on Experience Builder, so they probably won't ever change it.
LanceKirby2
Thanks @ZorbaConlen1 . I opened a case with esri and they have logged it as a bug in 10.9.1. Didn’t seem like they would have a resolution though.
