Draw Widget - Export and Import Drawings
5059
02-28-2017 12:53 PM
Status: Open
ShaunWeston1
It would be great if you could export and import drawings using the draw widget.
Workflow would be:
- User draws on the map
- User exports the drawing to a json file and closes Web AppBuilder
- User then returns to Web AppBuilder, opens the draw widget and imports the json file
- Previous drawings then appear on the map for the user to continue working on.
3 Comments
GordanBuckingham
This would be great. Check out the eDraw custom widget if you haven't already.
BrianFausel
Something like this already exists in the "Situation Awareness" widget, and I also think it would be very helpful in the Draw Widget.
In the SA widget, you can "Save" your buffer to a hosted feature service:
situation awareness widget save
When you hit save, the buffer is stored in a polygon feature service that is hosted in our AGOL account.
For this to work in the Draw widget, I would suspect you would need one of each type of feature service (point, line, poly, anno).
by Anonymous User
Jeremie'seDraw widget as Gordan noted does this perfectly.  I use it in all my apps.
