Change Web Map as an Esri-Widget
1886
09-20-2018 11:33 PM
Status: Open
StadtKarlsruhe
Hello,
wouldn't it be great if Esri developped a Web AppBuilder-Widget to change the layer list in combination with the background maps similar to the ChangeWebMap-Widget of the GeoNet-Community?!
ChangeWebMap Widget
In the web apps of the geoportal of Karlsruhe there are several needs to change the layer list and background map. I succesfully implemented the GeoNet-Widget in the menus "Themen" (english: "layer list") and "Zielgruppenkarten" (english: "maps for target groups") as you can see here:
ArcGIS Web Application
It works but the disadvantages are
  • few configuration possibilities
  • you have to create a web map for every combination of layer list and background map
  • the order of the web map-list can't be defined
  • the web app always restarts when changing a web map
  • in case of problems after updates I would prefer to use Esri-Widgets to get full support
So please like my idea if you are also interested in such a widget
Greetings from Germany
1 Comment
mariuskolleck
Super Einfall, würde uns auch helfen!
