Attribute table popup to show selected records
1437
11-24-2021 12:01 PM
Status: Open
WeiHan
Currently, when you use the select widget to select records on the map, you have to manually choose a feature class from the attribute table tabs and click on Options and select Show selected records to see the selecting result. Could we add a configuration option on the Select widget to popup the selected records in the attribute table so that the users can see the selecting results immediately and go from there?
2 Comments
OliviaZ_Meowth
Great Suggestion!
RamezRafatVolue1
This would be a good feature. If I get enough time before Christmas, I will try to develop this feature unless someone has already done that 🙂 !
