Viewer for Silverlight related data not visible
7693
8
10-03-2013 05:51 AM
FilipNevistic
Hello!
We created Relationship Class in ArcGIS Catalog.[ATTACH=CONFIG]28000[/ATTACH]
All created relations are visible in ArcGIS Map.[ATTACH=CONFIG]28001[/ATTACH]
We created application in Viewer for Silverlight, with ShowRelatedRecords Tool added in.
After application is created and started, point click triggers pop-up window and main attribute table is shown.
In right corner of pop-up window ShowRelatedRecords Tool icon is shown. If we click on this icon, related data table appears.
Then pop-up window is closed, and after another click on next point, ShowRelatedRecords icon is hidden from pop-up window and we can see only main attribute table.
[ATTACH=CONFIG]28002[/ATTACH]
Does anyone have solution for this problem?
How to adjust query tool to query related tables/records?
Thanks!
by Anonymous User
Not applicable
Original User: bangel
Do you have Feature Access enabled in the service properties for the service with related data?
FilipNevistic
Yes, Feature Access is enabled.
[ATTACH=CONFIG]28159[/ATTACH]
This is also enabled.
Any other idea?
by Anonymous User
Not applicable
My bad.  I just reread your post. It works once and then the icon doesn't appear again.  Is this correct?  It's been awhile, but I remember having something like this happen.  My fix was getting the most up-to-date query related data tool online.
DougRulison
Did you ever get a resolutio nfor this problem?  I am having the same issue and cannot for the life of me determine a pattern as a work around.  Did you get the latest tool?
thanks,
Doug
Any other idea?
Doug Rulison
by Anonymous User
Not applicable
Original User: drulison
I just downloaded the latest tool and i get the same results.  It always works on the first attempt, but subsequent attempts do not work, seems to be hit n miss.  I'm even selecting the same record and it does not return the "related records" tool in the popup.
Doug
by Anonymous User
Not applicable
Original User: gwalt_blm
Count yourself lucky.  With fresh install of Silverlight Viewer 3.1, the related table doesn't open at all.  Get a brief flicker, but nothing more.  As with you, the related tabular data from the feature access service shows up fine in ArcMap.  We have Silverlight v 5.120125.0 installed.  I made sure the web browser pop-up blocker was disabled, but no related attributes ever load.
GaryWalter1
Quick update on my previous post - the feature access service has to allow the Create operation (in addition to Query and Update).  Once I enabled that setting in the feature access service, the related data table opened as expected.
MitchellWiniecki
Does feature access need to be enabled to make the tool work?? I can't imagine so.  Never had luck with this tool.
