Viewer 3.2 Upgrade Issue
1262
12-09-2013 05:33 AM
BrianLeroux
I ran into a small issue upgrading to 3.2 and figured I would share in case anyone else runs into the same issue.
When you get to the point to click the Up arrow that upgrades your individual Viewer Applications, I ran into an error message which stated there was a HttpWebRequest_WebException_RemoteServer - Arguments:NotFound. After looking at the request in fiddler I found the message "The file 'C:\inetpub\wwwroot\Apps\PolicySearchTest\Config\Application.xml.bak' already exists."
So I looked in the Config folders of ALL my maps and found I had .bak files that may have been from the upgrade to 3.1 a while back. After renaming or deleting these files I was able to upgrade all my viewer applications.
Hope this helps someone.
PietaSwanepoel2
Thank you, Brian.
There seems to be more issues. Will hold out for a while before upgrading.
BrianLeroux
Thank you, Brian.
I finished upgrading my applications and all my add-ins to 3.2 yesterday. Went very smooth after the initial issue mentioned above. To be honest i probably would have held off on this update but I needed the fix for the pop ups not honoring the layer definitions. That was one thing i could never find time to fix myself.
I may find use of the new showWindow positioning and the INotifyInitialized. Now to find time to play.
