Viewer v 3.2 Query Tool  error
1422
12-09-2013 12:20 AM
OlegLukyanov
I have error  "Method not found "Void ESRI.ArcGIS.Client.Extensibility.MapApplication.ShowWindow(System.String, System.Windows.FrameworkElement, Boolean, System.EventHandler`1<System.ComponentModel.CancelEventArgs>, System.EventHandler, ESRI.ArcGIS.Client.Extensibility.WindowType)"."
with Query Tool in 3.2 version.
When I install Viewer in clean computer Query Tool work OK. I think this error is due previous Query Tool Add-in.
I try reinstall 3.2 and 3.1 versions but this error persists.
How I can clean my computer from all previous Add-in installations?
Sorry for my poor English.
Oleg.
PietaSwanepoel2
Oleg,
all the add-ins live in C:\inetpub\wwwroot\Builder\Extensions
If you remove the add-in within the builder (same place were you add the add-ins), it deletes the add-in from the folder as above.
It does not delete the add-in inside the apps Extensions folder, e.g. C:\inetpub\wwwroot\Apps\{myApplication}\Extensions
You can do that by hand to make sure it is removed
Also, clear your browser cache
