Using the _VisibilityChanged or _LegendChanged event to turn on/off a feature layer?
1140
09-09-2013 05:03 AM
YurongTan
I have a feature layer that is derived from a dynamic map service layer solely for Map Tip purpose.  The feature layer is set to 100% transparent to fool the eyes of a user that the map tip appears to come from the "underlying dynamic map service layer". Is there a way to sycn the visibility of a map service layer with a derived feature layer using the _VisibilityChanged event or _LegendChanged event of the dynamic map service layer?  below is the codes, but none work.  What do I miss?  Thanks
private void ArcGISDynamicMapServiceLayer_LegendChanged(object sender, EventArgs e)
            FeatureLayer myFL = MyMap.Layers["Water info popup"] as FeatureLayer;
            DynamicMapServiceLayer myDMSL = MyMap.Layers["Water info station"] as DynamicMapServiceLayer;
            if (myDMSL.Visible == true) myFL.Visible = true;
            else myFL.Visible = false;
OR ...
YurongTan
Using the _PropertyChanged event solved the problem.
YurongTan
