Use Flare Cluster with dynamically created points
4087
12-03-2013 11:28 AM
JohnPreston
Hi I have x,y coordiates storred in a database, which i load and create points on a map. There are points that overlap and I was wondering if the flare clusterer worked with points that are dynamically added to the map?
Here is how I add points to the graphics layer...
For Each item In ddsRequests.DataView
                Dim mappointX As Double = Convert.ToDouble(item.XCoordinate)
                Dim mappointY As Double = Convert.ToDouble(item.YCoordinate)
                Dim mappoint As New ESRI.ArcGIS.Client.Geometry.MapPoint
                Dim DefaultMarkerSymbol As New SimpleMarkerSymbol
                Dim clr As New SolidColorBrush
                clr.Color = Color.FromArgb(255, 255, 0, 0)
                clr.Opacity = "0.5"
                DefaultMarkerSymbol.Size = 10
                DefaultMarkerSymbol.Style = SimpleMarkerSymbol.SimpleMarkerStyle.Circle
                DefaultMarkerSymbol.Color = clr
                Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("GraphicsLayer1"), GraphicsLayer)
                mappoint.X = mappointX
                mappoint.Y = mappointY
                Dim IP As New IdentifyParameters With {.Geometry = mappoint, .LayerOption = LayerOption.all, .SpatialReference = MyMap.SpatialReference}
                Dim graphic As New Graphic() With {.Symbol = DefaultMarkerSymbol, .Geometry = mappoint}
                graphicsLayer.Graphics.Add(graphic)
                MyMap.Layers.Add(graphicsLayer)
        End If
Thank you!
PietaSwanepoel2
Should be fairly easy to do. Haven't tried it but here is the logic
The map.xml bit for clusterer looks like this:
<esri:GraphicsLayer.Clusterer>
    <esri:FlareClusterer>
        <esri:FlareClusterer.Gradient>
     <LinearGradientBrush>
         <GradientStop Color="#7FFFFF00" Offset="0" />
  <GradientStop Color="#7FFF0000" Offset="1" />
     </LinearGradientBrush>
 </esri:FlareClusterer.Gradient>
     </esri:FlareClusterer>
</esri:GraphicsLayer.Clusterer>
To reference it programmatically:
graphicsLayer.Cluster.....
Fill in the reset of the code
JohnPreston
Thanks Peita,
I get an error when using "graphicsLayer.Cluster" Is this the correct format?
John
PietaSwanepoel2
I used  C# to check that. Noticed you use VB. Assummed the reference to the graphics layer is called "graphicsLayer", similar to your example.
Full reference would be in
ESRI.ArcGIS.Client.Clusterer
ESRI.ArcGIS.Client.GraphicsClusterer
ESRI.ArcGIS.Client.FlareClusterer
Scratched some more in map.xml and found more attributes to set:
   <esri:FlareClusterer Radius="25" MaximumFlareCount="5" FlareBackground="#FF9BBB59" FlareForeground="#FF000000">
I haven't tested this or implemented it. Was just a suggestion of how to maybe get there
JohnPreston
Thanks Pieta, yes you are correct the graphics layer is names "graphicslayer"
I added the references you suggested, but I'm still not sure what to do with "graphicsLayer.Cluster". The error I get says "Cluster is not a member of ArcGIS GraphicsLayer." However, Clusterer is a property do you mean "graphicsLayer.Clusterer"? If so are there other properties to set?
John
JohnPreston
I got it. I was missing the spatialreference setting
ddsRequests.DataView.MoveCurrentToFirst()
            clr.Opacity = "0.5"
            DefaultMarkerSymbol.Size = 20
            Dim graphicsLayer As GraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayer"), GraphicsLayer)
                mappoint.SpatialReference = New SpatialReference(2926)
                graphic.Geometry.SpatialReference = New SpatialReference(2926)
