Toggle Builder Attribute Table control visibility from custom Search Add-in
1120
05-17-2012 03:40 PM
AntonioSergio
I want to toggle the Builder Attribute table control visibility  from a custom Search Add-in, visible if the search return results, collapsed if no results return, Is there a way to do this?
KatherineDalton
Hi Antonio,
Take a look at our Control in Layout with Toggle tool in the ArcGIS" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/samples/s... Viewer for Silverlight Samples. This should point you in the right direction. In essence it does the following and you would replace "ChartContainer" with the FeatureDataGridContainer or any other element you wanted to toggle. This sample uses an actual tool to do the toggling, but you could adapt this as needed.
   private FrameworkElement objectToToggle;
        public void Execute(object parameter)
            if (objectToToggle == null)
                objectToToggle = MapApplication.Current.FindObjectInLayout("ChartContainer") as FrameworkElement;
            if (objectToToggle != null)
                objectToToggle.Visibility = objectToToggle.Visibility == Visibility.Visible ? Visibility.Collapsed : Visibility.Visible;
In this scenario, you will need to go in to your layout and find the FeatureDataGridBorder and FeatureDataGridCloseButton and set their initial opacities to 1.
Hope that helps,
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
KatherineDalton
Hi Antonio,
Hope that helps,
Katy
AntonioSergio
Thanks Katy,
works perfectly,
António Sérgio
