Specify editable fields
2625
06-07-2012 07:49 AM
KarenEllett
When using the edit values tool, is there a way to specify specifically which fields will appear as editable?  I'd like to prevent some of them from being editable.
ThadTilton
When creating the mxd for your feature service, you can use layer properties to specify certain fields as read-only.
I haven't tested it yet, but the docs seem to imply that the user will be able to provide a new value but it will be ignored when applying updates:
"Field properties set in ArcMap will be exposed through the feature service; this includes field aliases, field visibility and a field's read-only property. Read-only fields include system managed fields such as objectid and globalid as well as fields set to be read-only in the map document. When applying an update, if a value is set for a read-only field the feature service ignores the value. When applying an insert, default values are applied for read-only and invisible fields. (Note: If default values have not been defined Nulls are applied.)"
