silverlight viewer without basemap
7675
10
09-09-2013 01:02 AM
rawanaisheh
Dear all
I'm started using silverlight recently, what I need is to add map service from my server only with the local coordinate , I don't need
any base map , I try to remove the base map but remove icon is inactive, see the attached picture, any help will be appreciated.
thanks
JuliaGalindo
Dear all
thanks
you have to do it in the settings(upper right corner in the screen). there you have the option.
regards,
rawanaisheh
regards,
thanks for reply I try to remove it from setting it is only removed from base map list not from the viewer it self so I still have the same problem.
JuliaGalindo
You are right, it does not work, what i did was to take away that option, so the basemap is on the application and can not  be changed.
regards,
rawanaisheh
regards,
yes it seems that the basemap can not be removed .
thanks
Noah-Sager
Howdy,
Unfortunately, this is a known software issue (NIM079517) in the Application Builder.
One option is to modify the settings in the "Map.xml" file in the Config folder of your application. You can edit the basemap and initial extent here.
Another potential workaround is to publish your own blank map and add that as a new basemap to the Application Builder. To do this, you can add a shapefile and choose "None" for Fill and Outline options, then publish it with caching enabled.
Helps this helps.
rawanaisheh
Howdy,
Helps this helps.
first of all thanks for your help, I try the second solution , I'm already gave  a published cashed map but how can I add it as a base
map.
Noah-Sager
No worries. Here's how to add a new basemap:
1) Click on "Settings" in the upper-right of the application builder
2) Select the "Basemaps" tab
3) Click the "+" button in the middle left of the screen to add a new basemap
4) Define the URL of the published, cached, new basemap you wish you use
[ATTACH=CONFIG]27399[/ATTACH]
5) Go back to the main page by clicking the blue arrow in the upper right
6) Go to Configure >> Basemap >> and select your new basemap
rawanaisheh
I do the same step , when I try to add my own base map a messege  said ok appears but nothing added to the viewer . see attached file.
Noah-Sager
What version of Silverlight are you using? I would recommend re-installing the Application Builder, possibly the newest available version, and trying again.
