Silverlight viewer URL parameter
3371
05-01-2013 01:07 PM
Hwa_SaupLee
How can I use URL parameter with the Silverlight Viewer?  similar with Flex Viewer.
for example: http://serverName/SilverlightViewer/index.html?config=Config/Map2.xml
I would like to use the exact same application with multiple map configurations.
Can it be possible?  It can be done in the flex viewer.
DannyDong
I wonder if you figured it out or not, but it is doable, like in the code snippet:
 if (HtmlPage.Document.QueryString.Keys.Contains("xVal1"))
                xVal1 = HtmlPage.Document.QueryString["xVal1"].ToString();
In the URL, you pass something like aspx?xVal1=100, or even htm?xVal1=100 to the code behind.
Z
BrianLeroux
Definately possible. I do something similar to what you mention. I am taking URL parameters when the viewer initializes and querying using the parameters to populate the map contents. Below is the code I use to get parameters from the URL.
public void getECFParameters()
            Dictionary<string, string> urlparams = HtmlPage.Document.QueryString as Dictionary<string, string>;
            urlparams.TryGetValue("CAT", out ecfCAT);
            urlparams.TryGetValue("DOL", out ecfDate);
            urlparams.TryGetValue("COV", out ecfCov);
            urlparams.TryGetValue("POLNO", out ecfPOLNO);
            if (ecfCAT == "null")
                ecfCAT = null;
            if (ecfCov == "null")
                ecfCov = null;
