ShowWindow Start Position
1383
02-07-2012 10:33 AM
DavidZhong
The MapApplication.Current.ShowWindow always popup the dialog window in the center of the application. Is there a way to change the start position of the dialog window?
Any help would be really appreciated.
David
KatherineDalton
Hi David,
No, you cannot specify the ShowWindow Start Position.
You could consider:
1. Put the tools on one of the toolbars on the OOTB layouts.
2. Add your tools (control) onto the layout of the page so it�??s not in a window that pops up in the middle of the screen. You may wish to see our document, Best" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help/index.... practices: Designing and displaying dialog boxes for additional information. For an example of adding a custom control to a layout, see our "Control in Layout" sample in the Interactive" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/samp... SDK.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
DavidZhong
Thank you so much Katy! This is exactly what I need.
DavidZhong
Hello Katy,
When I customized the layout by placing a control, if the controls are form ESRI or Mircrosoft libraries, I can see the added control in the customized layout in the viewer. just like the "Control in Layout" sample in the Interactive SDK.
However, when I placed a usercontrol created by myself to the customized layout, I could't see anything in viewer(the viewer is blank) after I changed the layout to the customized layout.   I can see the control in the customized layout.xaml in design view.
What I am trying to do is to customize the layout by adding a usercontrol which can comunicate with the map.
Your help would be really appreciated
David
