Query Tool Available
10007
16
03-27-2013 09:20 AM
RichZwaap
A new Query Tool is now available for the ArcGIS Viewer for Silverlight.  The tool allows users of the Application Builder to interactively build queries against ArcGIS Server services, presenting end-users with a simple dialog box that prompts for values to plug into the query.  End-users of a configured query tool are prompted to input query values into text boxes, drop-down lists, or both.  Results are shown on the map and in the Viewer�??s attribute table.  For developer's the tool's full source code is available.
To get started using the tool or exploring its implementation, simply download it from ArcGIS Online.
PanagiotisPapadopoulos
Can you try deleting the QueryTool.AddIns and then clear your browser cache or use another browser to upload it again?
I had the same problem with Chrome. I deleted the tool from Application Builder using Chrome.
After that I uploaded the Add-In using IE 9.
JamalNUMAN
Legendary Contributor
Hi Rich,
I managd to add this great tool to my Silverlight. The issue that after saving the web application and closing it the �??query layer�?� doesn�??t appear on the viewer or when start editing (refresh is applied)! It is not saved!
[ATTACH=CONFIG]24600[/ATTACH], [ATTACH=CONFIG]24601[/ATTACH], [ATTACH=CONFIG]24602[/ATTACH]
What might be the issue?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
I cant download the addIn, is the download link right?
Thanks, Manuel
Sure, the link is correct and is working fine.
http://www.arcgis.com/home/item.html?id=451259f8e47440f2b727442fe1b2f7c2
Alternatively, please, you may download it from the link below
http://www.mediafire.com/download/5rd436uehbr8cf1/QueryTool.zip
Best
Jamal
Jamal Numan
JamalNUMAN
Thanks Jamal, seems that the problem is that is not allowed from my work. I will try to download it from home.
Regards, Manuel
Hope you will be able to download it at home.
Best
Jamal
Jamal Numan
DamianFoster
Is there a way to define in the configuration of the Query tool, wildcards?
LaraRector1
With the tool "Query Layer".  I am setting it up to find a road name, but as someone else has already mentioned, if you use a query expression without the drop down list you must type in the full road name as it appears in the layer because there is no option for a wildcard with the LIKE operator.  ie.  Street Name LIKE "input road name".
Is this correct and will it be altered at all in the near future?
Lara
StevePickens
I have experienced the same issue as Jamal where changes are not saved to the Tool.xml file even though the "Changes Saved Successfully" dialog gets displayed. I have not been able to determine what causes the issue. I only seem to have issues with the Parcels layer. I have successfully added the Query Tool to do 8 different queries in the same application, however I have never been able to add one using my Parcels layer and have the changes saved correctly. I can watch the Tool.xml file timestamp in Windows Explorer and see if my changes were saved. If I then remove the offending Query Tool on the Parcels layer the changes are saved correctly and the Timestamp on the file updates to the current time. I can add another query tool accessing a different layer in the service and it works and saves correctly.
On another topic, I would also like to see the ability to concatenate a wildcard character to the end of the string entered by the user, only if the user did not enter one, when LIKE comparisons are made. I even forget to add the wildcard character myself while testing.
Steve
