Problem with reprojection
2337
04-27-2012 07:51 AM
by Anonymous User
Not applicable
Original User: rogeryc
Hi, I'm having the following issue:
[ATTACH=CONFIG]13884[/ATTACH]
The yellow flag is a point feature with WGS 84 zone 20S projection (wkid: 32720), in a operational layer. Using Bing or ArcGIS Online map, that point is correctly drawn by the viewer. The green star is a graphic added to a graphic layer in the same projection (32720) with the same x,y coordinate.
Why are they drawn in different places?
Regards,
Roger.
by Anonymous User
Not applicable
Can I set the SpatialReference of a Graphic Layer? In the "ArcGIS API for Silverlight" forum they ask:
"Does your GraphicsLayer Graphic.Geometry has its SpatialReference set? "
Regards.
