Override basemap maximum scale?
4069
5
06-01-2012 10:33 AM
KarenEllett
Is it possible to alter the code in the Map.xml file (or elsewhere) to force the application to allow the user to zoom in farther than the basemaps limits?  I understand that the basemap wouldn't display or look right, but we have some very intricate, high res spatial relationships that need to be displayed.  Currently I can't get it to zoom in enough.
(I apologize for yet another question!  I promise that I scour the forums, the internet, and all resources I can trying to figure it out myself before I bother you guys.)
Thanks!
JeffMcConnell
Try setting the minimum resolution of the map in a behavior or a tool.
MapApplication.Current.Map.MinimumResolution = Double.Epsilon;
Jeff
JeffMcConnell
Jeff
KarenEllett
Works like  a charm.  Thanks Jeff!
NancyGnanicys
<<<Very new to Silverlight Viewer, could someone direct me to where to find this in my application?  I went to Inetpub/wwwroot\Applications\TESTApp\Config and then opened my Map XML document, did a search for the
"MapApplication.Current.Map.MinimumResolution = Double.Epsilon;" as Jeff mentioned and found nothing written that matches even "MapApplication".>>>>
Nevermind, I figured it out, I just deleted all of the extent and Esri Tiled map services from it since I have a basemap already and that took out the maximum zoom extent since my basemap allows for zooming in very closely.
WilliamKaptein
I want this also but i cant get it to work. Can someone explain to me step by step how to do this ?
DanielMcCormick
Would like detailed steps to implement this as well.
Thanks!
