Layer Filter not working on secured services
5093
07-15-2013 04:07 AM
by Anonymous User
Not applicable
Original User: jungf
I've came across a problem with Filter Layer function on secured services. When I try to use Filter window on a secured layer the form stays blank:
[ATTACH=CONFIG]25917[/ATTACH]
I listened to the network communication and found out following:
When aplication is loaded, it opens the login form and user enters credentials. After that, layer is initialized using token:
http://SERVER/arcgis/rest/services/SERVICE/FeatureServer/0?f=json&token=7gcVolwT3rhHHCUCYhvArF3PWbnA...
Query request for getting data also contains token.
But when Filter Layer window is opened the service is called without token: http://SERVER/arcgis/rest/services/SERVICE/FeatureServer/0?f=json so the server returns an error:
[HTML]{"error":{"code":499,"message":"Token Required","details":[]}}[/HTML]
In Application builder an error is displayed after closing this blank Filter window:
[ATTACH=CONFIG]25918[/ATTACH]
I made tests on two independent servers and different data and both resulted in same error. Thereby I suppose that this is an bug. Can anyone from Esri confirm and resolve this?
Thanks a lot.
Filip
EDIT: Version of Viewer is 3.1.0.110
FilipJung
I contacted our local Esri distributor and they confirmed that this is a bug reported as #NIM091132: Filter tool in Silverlight Viewer 3.1 does not work on Secured Services for ArcGIS Server 10.1.1.
The error is showed in detail here.
I hope that patch will be released soon.
Regards.
Filip
by Anonymous User
Not applicable
Original User: nika_1410
I hit the same wall, it would be great if ESRI could release the patch as soon as possible.
TysonHaverkort
Can someone from ESRI confirm if this bug has been fixed version 3.2 of the Silverlight Viewer?
Thanks!
by Anonymous User
Not applicable
Original User: theurbanangst
Doesn't look like it.
