Here is a work-sround to set the max and min scales for application main map MyMap. It uses the MyMap_ExtentChanged(object sender, ExtentEventArgs e) event. This is to prevent the user from zoomming in/out outside the preset min & max map scales. ESRI can trweak it to make it better or simply to add a property for the application main map.
private void MyMap_ExtentChanged(object sender, ExtentEventArgs e)
double myMapScale = MyMap.Scale;
double SmallestScaleFactor = 300000, LargestScaleFactor = 50000000;
if (myMapScale < SmallestScaleFactor || myMapScale > LargestScaleFactor)
ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = MyMap.Extent;
double MapxCenter = (displayExtent.XMax + displayExtent.XMin) / 2.0;
double MapyCenter = (displayExtent.YMax + displayExtent.YMin) / 2.0;
double view_x = (displayExtent.XMax - displayExtent.XMin) / (double)myMapScale;
double view_y = (displayExtent.YMax - displayExtent.YMin) / (double)myMapScale;
double newxmin, newxmax, newymin, newymax, NewScaleFactor = (double)myMapScale;
if (myMapScale > LargestScaleFactor) NewScaleFactor = LargestScaleFactor;
if (myMapScale < SmallestScaleFactor) NewScaleFactor = SmallestScaleFactor;
newxmin = MapxCenter - ((view_x * NewScaleFactor) / 2.0);
newxmax = MapxCenter + ((view_x * NewScaleFactor) / 2.0);
newymin = MapyCenter - ((view_y * NewScaleFactor) / 2.0);
newymax = MapyCenter + ((view_y * NewScaleFactor) / 2.0);
ESRI.ArcGIS.Client.Geometry.Envelope LimittedDisplayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(
newxmin, newymin, newxmax, newymax);
MyMap.ZoomTo(LimittedDisplayExtent);
