deploy to website
3020
05-22-2012 05:44 AM
BarryJaggernauth
Hi
I am just getting familiar with the ArcGIS Viewer for Silverlight.
My questions is how can i deploy the silverlight viewer maps from a website rather than my local machine?
Any advice would be appreciated.
Thanks
Barry
KatherineDalton
Hi Barry,
From our Deploying" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help/i... Applications topic: When you are ready to deploy your Viewer application to a production environment, copy the published web application folder or folders from your development machine to the Web resources directory of the target web server. For example, if you created a new application called "Site1," you would copy the Site1 folder from the Apps directory of your development machine to the production environment. Depending on the configuration of the target web server, you may then need to configure a virtual directory to point to the copied directory.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
BarryJaggernauth
Thanks Katy!
ELIZABETH50
Thanks Katy!
Did you get it to work?  I read the instruction many times, but still I don't know how to make it availabe to users.
Is there a tutorial on how to accomplished  it?
KatherineDalton
Hi Elizabeth,
What stage are you currently at with deploying your website? Do you already have a server machine with IIS installed/setup? Is this something you manage or do you have an IT department?
Katy
