Date/Time field formatting - Viewer Silverlight
2929
10-09-2013 05:38 AM
SaraRayado_Perez1
I have configurated feature and geoprocessing services with ArcGIS Server 10.1 (database Ms SQL Server 2012).
The fields with data type "date" are displayed in the table of attributes as DD.MM.YYYY in ArcMap and as DD.MM.YYYY 1:00:00 AM in ArcGIS Viewer for Silverlight 3.1. The default "1:00:00 AM" comes from the geodatabase format, so I would not like it to appear when consuming the service in the viewer (it doesn,t appear in ArcMap because of the windows short date format configurations).
Is there any way to manipulate the date format in the viewer for Silverlight like in the viewer for flex?
I would appreciate any help. Thank you very much for your time.
RichZwaap
Sorry, there's not currently any way to configure this.  Since the time is important in some data, the Viewer defaults to including it in order to cover those scenarios.  This is certainly something we would like to address, but it does not look like we'll be able to in the forthcoming 3.2 release.
