CSV Export Issue
3043
04-05-2012 05:07 AM
BrianLeroux
I have a particular layer where there are fileds that may not have a value. Viewing the table for this layer works fine. However, when attempting to export as a CSV the data does not output correctly. If a record has any fields with no value the data for that record is pushed to the columns to the right. For example if I have a table with 2 columns names ObjectID and CustomerNumber and the CustomerNumber is blank in one record, on export the ObjectID for that record would now be placed in the CustomerNumber field and the ObjectID field would be blank.
Is this a known issue and is there any resoulution besides making sure all fields have data?
Thanks!
KatherineDalton
Hi Brian,
Unfortunately it is a bug. The Nimbus number is: NIM069739. At this point no workaround other than your suggestion to make sure every field has data.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
KatherineDalton
Hi Brian,
Katy
BrianLeroux
Hi Brian,
Katy
Oh well. Thanks for the info. Do you know how I would reference the table if I wanted to create my own export function?
JosiahThoen
I wrote a work around/ patch if interested.  See this thread: http://forums.arcgis.com/threads/84135-Export-to-CSV-Attributes-Shifted-Fields
