Can not open silverlight viewer 1.0.1 after install
1426
07-12-2012 11:50 AM
NancyGnanicys
I have deleted the application in IIS 3.5.1 sp1, removed the registry key HKEY_CURRENT_USER\Software\ESRI\ArcGIS Silverlight Viewer.  I have 32bit system windows XP. All my MIME types (.xap and .xaml) are there in IIS. When I install, the prequisites check list verifies all succeeded as well. I believe it could be a permissions issue? The last event viewer log gave me this error:
Event Type: Error
Event Source: ASP.NET 2.0.50727.0
Event Category: None
Event ID: 1084
Date:  7/12/2012
Time:  2:39:39 PM
User:  N/A
Computer: CITY-0294
Description:
aspnet_wp.exe could not be started. The error code for the failure is 80004005. This error can be caused when the worker process account has insufficient rights to read the .NET Framework files. Please ensure that the .NET Framework is correctly installed and that the ACLs on the installation directory allow access to the configured account.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
This is where I believe I need to go next............
http://support.microsoft.com/kb/315158
However I'm not familiar with ASP.net permissions and config files for that.  I didn't think it was going to be this complicated to start up, is there something else I am missing that I should attempt first before trying to fix ASP.NET stuff?
