Builder access http error 404
3856
7
04-03-2012 02:23 PM
SeanRedar
I successfully installed the application but when I try to browse to the builder site I get a 404 error.  All of the permissions seem to be in order so I don't think it is related to permissions.  We are running Windows Server 2003 64 bit.
KatherineDalton
The ArcGIS Viewer for Silverlight is supported on Windows Server 2003 R2 - is that what you have? If so, can you confirm you've set up the prerequisites appropriately using the following doc: System" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help/inde... Requirements
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
SeanRedar
We do have 2003 r2 and have met all of the other requirements.  Could it be we are using the 32 bit ASP .NET web services extension?  Its isn't specified in the system requirements.
RichZwaap
Hi Sean:
Do you still get a 404 if you include "/Default.aspx" at the end of the URL?  E.g. http://localhost/Builder/Default.aspx.
SeanRedar
Yes, still getting the 404 error.
MikeBowen
I am getting the same error after installing The ArcGIS Viewer for Silverlight 1.0.1 on Windows Server 2003 R2. Worked fine with 1.0. Did anyonefigure out a solution?
RockyM
Hi Michael:
Did you have the issue resolved? I am having the same problem (with Windows Server 2003 R2 SP2).
Thank you
RM
JosiahThoen
I'm not sure if it is relavent but I had the same issue.  I have a Win 2003 R2 server.  Our IIS is running in 32 bit mode so I removed the wildcard application maps for C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll from the builder application configuration.  After that, the builder started up without getting the 404.
  1. Open IIS Manager
  2. Right click on the Builder virtual directory and chose properties
  3. On the virtual directory tab, click on the Configuration button
  4. On the mappings tab, select "C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319\aspnet_isapi.dll" from the Wildcard application maps, then click remove.
  5. Click Ok to close the window and then Ok to close the virtual directory window.
