Adding Opacity Slider to Map Contents tool
2842
04-09-2012 02:39 PM
GerardoGarza
Is there a way to add an opacity slider to listed layers in the Map Contents control of the viewer?
Or would I need to create a new control?  I would like to avoid that, if possible, as I like the other functionality of the Map Contents control.
Thanks.
KatherineDalton
Hi Gerardo,
Yes, you would actually need to create a control, but it could be something you include in the layout itself. See this forum post for more info: Layout" rel="nofollow" target="_blank">http://forums.arcgis.com/threads/51913-Layout-Customization]L... Customization.
Hope that helps,
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
GerardoGarza
Thanks for the help Katy.  I like your solution.
My only concern is dynamic service sub-layers which are not selectable. We have a service with 20 sub-layers and complex symbology.
We may have to load the ones that need different opacity as separate layers.
GG
KatherineDalton
GG
Yes, that is probably the most appropriate solution in this case.
Katy
