Zoom in Scale Range
775
03-14-2012 11:23 PM
NadirHussain
Dear All
  i have question.if i implement zoom visible scale range in mxd document for some layers.this functionality will be shown in rest
service or not.
  if this is not in rest service how can i implement zoom visible scale functionality in flex application for layers.
   Thanks in advance.
RobertScheitlin__GISP
Nadir,
  Yes, once you set a layers min and/or max scale in the MXD and publish that map the REST endpoint will honor that scale setting. To actually get a zoom to make layer visible in Flex Viewer you need my TOC widget as it has that capability.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
