Simple Compiled Export to PDF Widget
952
03-14-2012 02:15 PM
ChadHall
Is there no compiled "Export to PDF" widget available in Flex.  Seems silly that it still isn't incorporated into the base code from esri but I've been searching through the forums and can't find anything that works.  Maybe I'm not looking in the right places but all I want it to do is export the webmap to pdf and possibly set the page size and orientation.
Thanks in advance!
Chad
BjornSvensson
Esri Alum
For the 2.x release that is correct.
The 3.0 PrintWidget supports printing to PDF using your own layout template (as set up within ArcGIS).  This will require ArcGIS Server 10.1 and the ArcGIS Viewer 3.0 for Flex.  This was released in beta end of last year, and the 3.0 prerelease will be available later this month.
